Question about HP PSC 1610 All-In-One InkJet Printer
What does it means when the check paper light on a HP PSC 1210 All-In-One printer stays on even though there is plenty paper in printer?
This happen after a jam was cleared!
    New Friend:
  • 16 Answers
Most probably there's still a bug, insect or just a small piece of anything caught between the roller or wheel after you cleared a paper jam otherwise a spring, hook tension-er across the roller is not in-place.
Posted on Feb 23, 2012
6ya staff
SOURCE:
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: driver for hp psc 1210
if yo have internet connection pls download the driver from this link http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HP/Hp-psc-1210-allinone-210.shtml or go to any nearest cyber cafe and download it bye
Posted on Oct 01, 2007
Anonymous
  • 80 Answers
SOURCE: How to Clear carriage jam
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Posted on Dec 04, 2008
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: flashing lights on hp psc 1210
After i posted the comment for you, I found thru HP's website a list of the lights flashing and what it means depending on the pattern:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00007641
Posted on May 13, 2009
Anonymous
  • 169 Answers
SOURCE: hp psc 1210 It says no scanner found ?
as the copier works its not a hardware concern.if the scanneris not found it means the drivers are not installed properly.Try uninstalling the drivers completely from the device manager as well as the printer and faxes and the scanners and cameras(if possible delete the ebtries in the registry as well that are related to the software and the VID and PID keys from there).Then try a plug and play.....see if it works....
Posted on Jun 24, 2009
Anonymous
  • 434 Answers
SOURCE: Are there any releases for a paper jam in an HP
1) Power Off.
2) Disconnect USB cable and power cord
3) Clear the paper jam from the back of the unit by opening the rear access door. Turn the dial on the rear access door counter clockwise, and then pull the door toward you to remove it
4) Gently remove any paper from the rollers. Get all the pieces - any bits left inside will make it more likely to jam with future use
5) Reattach the rear access door. Gently push the door forward until it snaps into place
6) Reconnect the cables and power cord.
Try your print job again.
Posted on Dec 21, 2009
Testimonial: "That completely answered my question--I did not know there was an opening at the rear. I found more jammed paper than I even expected! Thank you!"
Paper jam
well..you may need to remove the software, and re install it...
and also, unplug the printer for around 5 min
May 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer won,t work
I can't get my 1210 hp printer to turn on
May 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc 1210 will not print
Please check the printer status at control panel printer properties if it is offline or ready. Restart your computer if necessary, you will notice all pending jobs will be printed as long as there is no problem with the connections of cables and drivers. Note: Do not cancel printing jobs in the middle of sending data mode to printer or queing instead you have to remove all papers on tray and wait for the error "paper out or empty" then there click Cancel. Hopes this helps.
Best regards,
Rosener Guyano
Feb 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer blinking
The E usually represents paper jam
unplug from wall socket and then replug and try printing
Jan 21, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP 1210 All In One Printer
see this is the common problem i got so many query regarding this proplem ,you can easily solve this problem , when you placing the paper in paper tray be very carefull put very slowly inside when you feel a little bit of resistent stop it that mean paper is properly inside dont put so hard inside. bye
Aug 12, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 Not Printing
Hi My first quesiton to you would be: What version of windows are you using. If you are using Windows Vista you will need to go to the HP Site and download the new updated drivers for the new OS. Second Question : Are you using genuine HP printer catriges? If so make sure the contact point where the catrigr and the printer meet are clean and free of dust. Try re seating the cartriges and re calibrating th printer. I checked with HP online tech support and they backed me on this. If you have any more trouble feel free to email me : hartmansp@inbox.com Have a great day.
May 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
103 people viewed this question
Ekse
Thomas F. Schneider
