This was a floor model and the control board pads were scratched pretty bad. So I replace both the pads and the board and also have put in a new Evap Fan motor. Everything is ok there. I put in a new water filter and cannot get the order (amber) light or the replace (red) lights to go off. I have pressed the reset pad for over 3 seconds but still no help. Now, when I press the door alarm, the amber order light goes off and when I press the temp pad, the red replace light goes off? i dont want to operate the fridge with the temp or door alarms off so everything is on?
SOURCE: maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
SOURCE: filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
SOURCE: Maytag MF12568AEW (white) Problem
For temporary relief of problem, disconnect power to front panel. The connector is located under the left door hinge cover on top left of refrigerator. Unscrew cover to remove.
Call Maytag, 1-800-688-9900, try to get the automated system to connect you to a real person (try saying "representative"). Explain to rep that you are aware this is a common problem with the HV Control Board - Part number: 1206507. Maytag is aware of this issue and said to me that this is an "improved" part. For me, they shipped the part out Fed Ex and set up a time for a serviceman to come out and fix it - all at no charge. I didn't want the hassle of waiting around for a repairman so I replaced it myself. It's pretty easy. The part came with instructions for programming. Here's the steps to replace if you want to do it yourself. *** I'm not a professional. Do this at your own risk. ***
Repair:
1. Pull the fridge from the wall and unplug it.
2. Wait 15-20 minutes
3. Remove the screws securing the HV circuit board cover on the left
rear side of the fridge. (left as if you were facing the rear of the
fridge)
4. Remove the clear plastic cover.
5. Verify that the fridge is unplugged.
6. Remove the 4 wiring harnesses from the circuit board. Using your
finger press down on the locking tab while gently pulling the wire
harness out.
7. Once all the wires are free, remove the circuit board by pressing
back the plastic retaining tabs while gently pulling the board out.
8. Insert the new board oriented the same way as the old. The board will snap into place.
9. Reconnect all 4 wiring harnesses.
10. Replace the clear plastic cover
11. Replace the steel cover and secure with the 4 screws.
12. Program the new circuit board according to the included
instructions. Programming requires that you enter a specific number
listed on the inside of your fridge into the front panel, this in turn
programs the board. Without this step, the fridge will not work. It's the number after CODE on the tag that includes model/serial number
Programming Mode:
1.Press and hold the Door Alarm Keypad.
2.Press and hold Freezer Temperature Down Keypad.
3.Release the Door Alarm Keypad and wait 3 seconds.
4.The control will display PE to indicate the programming mode.
5.Entry is confirmed by pressing the Freezer Temperature Down Keypad - once more.
6.The
control will display the current Program CODE.The value should be
validated with the Program CODE printed on the unit serial plate.
7.Press the Refrig Temp Up Keypad or Refrig Temp down Keypad to change the digit value with each key press.
8.The decimal point indicates the selected digit. Press the Freezer Temp Up keypad to select the next digit.
9.Once
the desired Program CODE is displayed, press and hold the Freezer Temp
DOWN keypad until the Program CODE begins flashing indicating it has
been saved.
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Press and hold
the Light and Lock pads until the Change Filter light blinks (approx 3 seconds)
the control is now reset for 12 months or another 416 gallons of water. Click here for a PDF of your Model=>
MZD2766GES_Use_and_Care_Guide I
will be here to answer any other questions you may have. If helpful please rate
this solution, Thanks, Sea
Breeze
