DP 55441
Check your settings on the TV you might have a setting that tells it not to remember. You can try to do a reset of the TV to factory settings that might solve the problem also. If this does not work then you might have a bad signal board.
you can get parts for this tv at www.interliquidparts.com
Hello.
You did not say if you were using cable or antenna. If cable, you need to use the remote that came with the TV. Get into the menu and look for channel setup or an equivalent heading. in one of your menu schemes will be a selection fot ant. or cable. Select cable and the other channels will magically apear when you exit the menu option.
Good luck.
