That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
