SOURCE: I am looking for a owner's manual for CardioZone
Go to treadmilldoctor.com or call them@ 1-800-750-4766 since Keys Fitness went out of business they bought the parts inventory I am assuming that they will have manual for you unit.
SOURCE: Tech said proboble board the
Dear Sir:
The best way is to go to the company, and they can resolve your problem.
Otherwise you will be lose your time. Remember the factory has many options with the manufacturer of the screen, and gave the o.k for your equipment.
sincerely
SOURCE: Cardiozone Club HR T Error Code SI2
see the details and fix it. God bless you Error
- "SI2 At Power Up" Symptom: Indicates
the OVP (Over Voltage Protection) circuit on the controller is active
and belt will not move. Solutions:
Check
for RAIL and LVS LED's to be lit. RAIL and LVS ok?
Replace F2 fuse RAIL not lit,
but LVS ok? Replace F1 fuse
SOURCE: Speed sensor of DC Motor treadmill making noise.
the speed sensor NOT make noise, is the main motor see the diagram attached.However tight any connector or plug very well, and test the s. sensor for open or defective and replace. You can RUN the software calibration for easy diagnose, troubleshooting, and fix it.
You must test the input voltage motor, if there are the motor need repair, bearing, shaft, or winding defective.
God bless you
Error
- "SI2 At Power Up"
Symptom:
Indicates
Solutions:
Check
RAIL and LVS ok?
Replace F2 fuse
RAIL not lit,
