Question about Frigidaire GLTF2940ES Front Load Washer
No spin i have a frigidaire GLTF2940ESO front loader and we are getting the error e47
  • cmarquez44 Oct 30, 2008
    thanks it was the door lock
    Novelist:
    Champion:
  • 261 Answers
E47 and E48 are door lock error codes, also check the wire harness connections too.
Posted on Oct 29, 2008
6ya staff
SOURCE:
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
E47 error
Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Jun 28, 2008 | Frigidaire ATF6000ES Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
752 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
