My washer recently has not been spinning all of the water out of the clothes. I took some of the clothes out and put it in for a second spin and the drum would not move. I had to have only 2 towels in there for it to spin and the water was still not coming out. I have cleaned it out with a rag. There doesn't seem to be any water laying in the bottom of the washer; it just won't come out of the clothes. These were not big loads either. Thanks
I have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Series 70 kenmore washer makes a gravely sound...will not agitate nor will it spin out. Replaced motor coupling last year...gear mechanism of some kind???
If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch.
Mine just did this, too, yesterday! You need a new motor coupler. See this page for the part and disassembly tips.
www.applianceaid.com/procedures.html
Ressa, there could be a couple of things going on here but let's start with the nuetral drain. After agitating the washer should enter a nuetral drain period of about 90 seconds before spinning. Your water in the tub should be gone. You can observe this by taking a small screw driver and holding down the lid switch during a regular load. If it's not going into this nuetral drain your clothes are going to be wet. This is a gearcase problem which is covered under warranty for 5 years, part only. Other things to consider is a restricted drain hose or clogged pump. Catriver..post back.
Kenmore series 70 washer makes loud clicking during agitation
Tub spring fell out of the washer
My washer,(sears 70 series) will not let the tub fill. It just runs out. But not all the time. What could be the problem, please.
Trishy
Same type of problem, I noticed it isn't spining fast enough to ring out the cloths but when there isn't anything in it it spins much faster and better.It's just not pinning fast enough with cloths in it.
Coot
my basement floor is getting soaked around my clothes washer and it also isn't spinning the water out of my towels
I have the same problem and we bought this washer used so I am wondering if it is going to cost alot to fix the problem or if we should just break down and go buy a new washer? Help!
My 70 series Kenmore washer does the same thing. The water fills the washer, but the agitator does not work and the spin cycle does not work.
I would like it very much if someone could tell me what parts I might need and a diagram of the machine, and some instructions if possible. I could probably do without the instructions, but anything that makes it easier would be eagerly welcomed.
I have a washer Kenmore 70 series that is not draining the water and is not spining either, please help me with any solution.
Thank you
Wow did everyone's washer start doing the same thing at the same time. Mine won't spin or agitate and this started yesterday.
i have sears 70 series. it has allowed the water to flow into the drum but will not wash or do anything else. can you help please
If the symptom is that the water will not drain (the drain pipe sounds like it is trying to expel water), what are the failure points and how should they be diagnosed??
Constructive replies are appreciated: coronabeach at gmail
the lid doesn't click like it used to....and it doesn't spin nor drain.
My kenmore washer does not spin all the water out of the clothes and therefore the clothes take over 3 hours to dry (1/2 load or full load is about the same). Dryer is new. washer is 4 years old. Model number 110 24632300.
will not spin water out anymore.please help.
My girl friends washer will fill with water and agitate.
Then once it is finished it just sits there, does nothing. No motor sound, nothing. It will not spin, drain, anything.
I have tried several settings on the dial, they all agitate and thats it.
I am in the process of disassembling and troubleshooting but even though I work on million dollar acid processing equipment...I don't know where to start on the washer! :)
