To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
SOURCE: Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
