SOURCE: the freezer side is freezing. The fresh food side
There is an opening on the lower portion of the wall that separates the two sides. check to see if this is closed. Sometimes, this happens in cleaning, etc. If it is open, reset the refrigerator setting at the top of the unit and see if the opening opens.
If that is not the problem, look inside the freezer down near the bottom at the back wall. There is a breather vent, I will call it, there. Check to see if it is frozen over or has excessive ice.
If it does, it probably is the Thermostat. There are two names used for the Thermostat in the parts/repair business. Some refer to it as Thermostat and some use the term "Metal Clip". One in the same. You can purchase this item from Appliance Parts or any appliance parts provider and put it on yourself as I did or you can call a repair person which will cost considerable more.
BEFORE COMMENCING ANY REPAIR, BE SURE YOU UNPLUG THE UNIT FROM THE ELCTRICAL SOURCE.
Now to get the bugger in. Take all food out, take shelves out, get approppriate screwdriver and remove screws from back panel and remove panel. You will see the Metal Clip/Thermostat clipped onto a brass tube that has some lead wires connected. Observe their allignment, unplug gently, remove old Metal Clip, Insert new Metal clip being sure to connect the wires. Put everything back together. Leave shelves and food out, until you see the ice melts to be sure everything is okay. I did this to mine when this happened to me. Ice won't melt instantly, but in a bit of time will. Good Luck. Let me know if it works for you.
SOURCE: whirlpool model ED22TQXGNOO. No cooling only warm
Be sure to replace back. Extremely neccessary.
Try These
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
