Lands Phones Logo
Anonymous Posted on Feb 28, 2012
How do I turn off call forwarding - Panasonic (640005) for KX-TG2700S, KX-TG2720S, KX-TG2730S, KX-TG2740S Cordless Expansion Handset
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Feb 28, 2012
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
10528
Points
173
Http://www.ehow.com/how_4794323_turn-off-call-forwarding.html
ok.this article is usefull!!!
pc tablette
tablette tactile
When someone in office calls my phone the intercom picks up instead of ringing. How do I turn that off? we use the NEC 80 version 2.25
The phone people in the office should be able to turn off call forwarding and auto answer
Call Forwarding
Call Forwarding - NECDSX.com
www.necdsx.com/dita/features/call_forwarding/call_forwarding_feature.html
  1. Cached
  2. Similar
Call Forwarding permits an extension user to redirect their call to another ... in the Call Forwarding programming mode - the same as pressing INTERCOM and ...
How do shut off call devirter
Turn Call Forwarding Off from the Device ' Verizon Wireless
www.verizonwireless.com/.../knowledge-base-17268/
Verizon WirelessIf you're not receiving calls, callers are not getting through (e.g., fast busy signal, ...calls after turning off Call Forwarding, check additional settings (e.g., Do Not ...
Turn call forwarding on or off - Sprint Phone Connect 2
support.sprint.com/.../Turn-call...off.../WScenario_54...
Sprint CorporationTurn call forwarding on or off - Sprint Phone Connect 2. Last updated: Oct 12, 2013. article View all tutorials. Did this solve your problem? Explore Device. Calls.
Call Forwarding (*72) - Bright House Networks Support
1helpful
How do I cancel I am here from the station I set it up (mitel phone) or from the station I had forwarded (analog)?
If you forwarded the analog to the digital you probably used a feature access code. So this code will either turn it off if entered into the forwarded phone. Or there is a call forward cancel fac that would turn it off. There may be a clear all features code that programmed that would cancel the forwarding as well. All of these options would need to be dialed from the forwarded (analog) phone.
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
Gear alignment on outboard motor
When the gear box ix in forward, it should make a ratcheting noise when rotated forward and should not turn at all when turning in reverse (or be resistant as your back spinning the water pump -don't do that) Once in gear (forward ) you should be able to mate the shift to the motor. I have removed the prop and nut and used a remote start to spin every thing together, but requires a lot of safety precautions.
If you are working on an older mercury, that shift rod can work both ways with disastrous results if you over spin the shifter to the back side of the detent.
Sep 17, 2012 • Boating
3answers
How to turn off call forwaring
My dear,
All you have to do is, enter #33*0000# and dial from your phone. hope this helps
Flywheel won't turn forward
You must have a small piece of thread stuck in the raceway that is probably why you can turn the balance wheel backwards but when you turn it forwards it jams again.
4helpful
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
2answers
How do you turn off phone forwarding? Somebody inadvertently has their phone forwarding to another extension. Lucent Partner 18d.
It depends on the kind of telphonesystem and the kind of forwarding.
Generally the procedure is #code# where code is
21 for call forwarding unconditional
61 for call forwarding on no reply
67 for call forwarding when busy
On most mobile operators you can do #002# or ##002# to take the all in one go.
On some fixed (analog/PSTN/ISDN) lines you can use #001# to take them all inone go.
Some PABXes(officephones) also have call forwarding on precense (lunch, meeting. etc) and this is often turned off with #23#
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
