SOURCE: Samsung LNT5271FX/XAA can not be turned on, keep
I had the same problem. It is the capacitors. You can fix this yourself if you have a saudering gun. It is very easy and costs about $10 or less. You can even buy a cheap saudering gun. You just have to replace the bad ones and it will work fine after.
SOURCE: Is it possible to get a replacement owners manual
Try www.samsung.com for manuals etc.
Hope that helps.
SOURCE: the infor on my tv is: model code LNT5271FX/XAA
Definitely a problem caused due to faulty power supply board. Most likely cause, faulty capacitors(electrolytic/surface mount or both) on the power supply board. The easiest way to fix it would be to replace the power supply board. Replacment board costs about 75-100$ for a set of this size.Would you like to replace it yourself?
