Please wait for extended time then SC 672. Have tried another HDD, reseated all connectors on control board and control panel as well as checked all other connectors. Tried reloading firmware thru sd card and didn't recognize the card. tried booting with HDD disconnected and still codes out with SC 672
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
The machine don't respond to this code even when I restart it I don't know what's the problem My machine is Gestetner Dsm 725 It gives me this message" Functional error sc 672"
In mine case The only solution was to clear the NV ram sp 5-801(first backup Sp 5-824 and print smc, incl.non default sheet if possible)
Contorlar brod
SOURCE: sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Cannot go into service mode at any time either
This is a MP6001 B?W machine
My richo aficio mp 2510 copier displays error code sc672. How can. I fix this?
Cheng contoler
