Stuck at Dell splash screen.
Hello, I have pulled out hair over similar problems. You either have an internal problem inside of the TV or you are losing your source for the picture.
These sets usually have a a Menu which tells the TV to go to a certain input socket for its feeding signal. If you have a bad cable or USB plug, the TV loses its feed and displays the Base Dell Logo.
This feed can be a HDMI multiple wire, or if you have a tapeplayer, CD deck, or Computer feed, they may be toggled separately. On some of my older equipment, I need to switch the TV ports through my Remote to get the appropriate appliance to show on my TV screen.
Depending on your Warranty, you may want to call Service. Sometimes dust can cross circuit the electronics and cause the problem you have. The cable feed wire can also be shorting and causing a loss of signal. Check you cable connections.
