It just happened to me. the water pump made a lot of noise but not pumping out water in my hotpoint wma46. the actual problem was that the water pump has got water inside over the year. removed the water pump from the washing machine. removed the three screws under the pump.the top cover should come off, then carefully remove the middle cover that holds the splindle and the magnet (just pull out like a cup cover), then clean and dry all the parts .use some silicon sealent to create better seal when putting the pump together.
If this washer has a accsess panel to the water pump they usually have a filter that catches debris and bigger items before they go in the water pump and destroy it i have three girls at home who have lost small socks bobby pins and a multitude of other things in this cup it just simply screws out from the houseing by the water pump un plug your washer pull the acsess cover and uncrew the filter you should see it by the water pump if you could take a pic and put it on i could help direct you more
