not yet. Looks like the TV does not make it through the boot process & turns offnot yet. Looks like the TV does not make it through the boot process & turns off
You can't post conmments that contain an email address.
If you keep getting this problem(green light turn on for 5 to 10 seconds then TV shuts down along) you get to try this: On ebay seach, type in "40E210U dead" there is one solution, good luck!
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
