www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
Here are some instructions as well for your RCA Remote: Programming a device using the Code Lists:
Find codes for each device and brand below.
Press and "HOLD"
CODE SEARCH.
Press and release the TV, VCR or Cable button you want
to set up. If programming AUX for a device, press and release AUX first
and then the device to be programmed (TV, VCR or Cable). When the selected
device button flashes proceed to the next step.
Enter the three digit
code from the TV, VCR or Cable Box code lists.
Release CODE SEARCH.
With the device on, press another button, for example CHANNEL UP. If
the device responds, no further programming is required. If the device
does not respond, repeat steps 1-5 using another code number from the lists.
If you have tried 5 remotes I would have to say that the set has a problem in the remote circuit. You will need a tech to look at it and repair it. Let me know how this works out for you.'
Code For Model RCR311S
Code 1003 for Panasonic TV
Code 1054 for Panasonic TV
Code 1062 for Panasonic TV
Code 1109 for Panasonic TV
Code 1170 for Panasonic TV
Code 1248 for Panasonic TV
GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Here is a list of codes for your remote. Please follow any of the links below to get your codes. Results 1 - 10 of about 324,000 for rca universalremotecodes. (0.26 seconds)
Search Results
Universal Remote Control CodesCodes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more. www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
