WONT TURN ON.RED LIGHT ON,NO CLICKING NOISE WHEN TRIED MANUALLY
Hi most likely it's your signal board my second guess would be your power supply.
You can get parts for this tv at www.interliquidparts.com
SOURCE: wont turn on
Hi, This sounds like protection circuitry kicking in or muting of some type. This can either be caused by no input signal or internal fault. First check/try different input signal sources such as your cable, DVD. If no go, try unplugging the unit from the mains for a couple of hours or verify from your manual how to do a hard reset. After the reset and no change, you probably have to seek the services of a qualified professional since chances are,this require opening the unit for diagnosis and repair. Hope this be of some help/idea. Good luck and kind regards.
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
SOURCE: televison wont turn on but red light flashing and
You can't fix it yourself, it needs professional.
SOURCE: won't turn on makes clicking noise
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
http://www.retrevo.com/support/Samsung-HP-R4262-TVs-manual/id/275dj896/t/2/
Above is your user manual, below is your service and repair manual.
http://www.scribd.com/doc/3997084/Sony-Service-Manual-TV-KV36XBR450-Chassis-DX1A
Really, with something under a year old MUST be covered by a merchantability cover. A unit such as this can reasonably be expected to last more than 8 months of use, even if on 24/7. In my professional opinion, you should return the unit, and demand that it be repaired, better yet replaced. This really is unacceptable. You need to contact a head office, and relate this all to them, Consumer Guarantees Act, gives you this right of redress, and the supplier must remedy NOT the manufacturer.
