I bought this tv at the pawn shop and now it won't turn on. The vizio logo is not lit. I opened it up and check the fuse which is good, the capacitor is good on the power supply/board. Could it still be the power supply or something else? Thanks in advance
Hi if nothing is coing up at all then you provably have a power supply issue.
You can get parts for this tv at www.interliquidparts.com
SOURCE: i bought a used vizio tv at the local pawn shop.
Download maual here: http://70.182.180.218/documents/downloads/hdtv/VW22LHDTV10T/187Manual.pdf
It will tell you how to reset the password.
SOURCE: Vizio TV 2006 vx32Lhdtv doesnt work.
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make
sure the backlight still works. I ordered a new "main PCB" from
tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I
used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
Testimonial: "If all things are equal than the solution is at hand. I thamk you!"
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Testimonial: "alteans is very helpful."
SOURCE: my vizio 42 picture does not come on but the vizio
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Can anyone help? I don't need a website to buy anything.
