LG 42LC7D-UB Television Logo
Anonymous Posted on May 23, 2017
Green power light and remote stopped working
Hey i bought a 42lc7d-ub tv from craigslist for really cheap cuz the remote didnt work. I changed the board that had the IR reciever and the led indicator (on the front panel) but im still having the same problem...  The remote and the green power indicator aren't working.
The part that i changed was EAX35562301 (2)
I'd love to get the remote working, the power indicator i could care less about, but i assume they are connected in some way ;)
Thanks J
2 Related Answers
Anonymous
  • Posted on May 25, 2010
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Anonymous
  • Posted on Nov 22, 2011
SOURCE: LG 42LC7D-UB, Bad LCD Controller Board????
Steve, that was awesome. Thanks a bunch. I already have the tools and I can get the solder easy enough. Thanks a again. I went to Best Buy this weekend and all they could say is that the entire board would need to be replace and that they really recommended a new tv as the cost for the new board would be as much as a new TV.... :( typical of them!
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will come...
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Lg42lc7d tv (35 total in sports bar) utilizing 5 Crestron av switchers CNX_PV1D8x3. Remote touch screen to control everything. All is well for last 2 years and now some tv's are not turning on. Have to...
you have some bad power supply.inside the tv's.you need to try several time to power up tv.that way in not coming up by remote.remote only power tv once.
2helpful
2answers
2answers
Cuts off
Most likely the power supply board.
Lie the tv down on a bed and unscrew the back. Its only about 9 screws around the edge and look at the power board, on the left, see if theres any burn marks.
I have a brand new board I bought the other day for the same issue but before I replaced it, stupidly, I checked with LG and turns out mine is still under warranty so I'm stuck with a new board.
Let me know if you want it. I'll match any price you can find online.
Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
