I get 2 samsung MH060FXEA4B on wich are connected 4 samsung MH020FWEA and 2 MH026FWEA. they are on heating mode at 20°c. This morning one of my air conditionner Samsung MH026FWEA has stopped whith an E559 error code. I do not find the meaning.
If i switch on the device, it stop after ten seconds again with same code.
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
I had the EXACT same problem, even though I don't know my model number.
I called the technician, and from what I understood, all he had to do was reset the outside unit, and everything was back to normal. Paid him almost $200 for 20 minutes work :(
You can reset the units. If you don't know how, I believe you can ask for help here on fixya.
I have 4 units of MH052FPEA Samsung to one Unit MH080FXEA4, and i have the same error problem (E559). How to reset samsung MH080FXEA4 exterior unit?
Any idea how to do it Joaquim?
