Cars & Trucks Logo
Anonymous Posted on Mar 04, 2012
Ihave a 99 nissan sentra.. it started squeaking.... like grinding... had rack and pinion replaced, brakes replaced and wheel bearing replaced.. its still squeaking bad, specially when not accelerating
Fixed rack and pinion, brakes, and wheel bearing... what else could be causeing this... seems to be doing this after i drive it for a bit and it heats up.. when i turn it it stops...... i need help bad thanks
  • 1 more comment
  • Anonymous Mar 04, 2012
    Its starts squeaking when Ive driven it for a bit... its the front end ...not under the hood... it sounds likes its around the tires or the steering..... like grinding but brakes and calipers are good.. brakes were replace, so was rack and pinion and wheel bearing.... doesnt squeek til it gets hot and then its like metal on metal. when u turn right or left, it stops as long as u are turning then starts back up
  • John McNary Aug 10, 2014
    The CV Axles may have some problems
  • Hannah Schroeder
    Hannah Schroeder Oct 06, 2017
    It's strange that the car squeaks and grinds when you're not accelerating. I have a similar problem, but I haven't replaced the brakes in my Honda. I think I might take my car to a brake repair service to see if the fixes the problem. I hope you get your issue fixed as well.http://www.specialistautogroup.com.au/ou...
raj somaiya
Level 3:
  • Cars & Trucks Master 5,370 Answers
  • Posted on Mar 04, 2012
raj somaiya
Level 3:
Answers
5370
Questions
0
Helped
3568517
Points
14579
For squeaking problem,the help links are provided below.Click the link below to go through the procedure :----squeaking under hood? http://repairhelpcenter.blogspot.com/2012/01/clutch-squeaking-under-hood.html
----------Squeak and grinding sound is heard when brakes are applied? http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
-------------Clutch squeaking? http://repairhelpcenter.blogspot.com/2012/01/clutch-squeaking-under-hood.html
---------Squealing at start up on car? http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
-----------This will help.Thanks.
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on Aug 07, 2009
SOURCE: rack & pinion replacement
there many web sites that offer tech suppurt, even Chrysler, just start looking, also Napa Auto Parts. Auto Zone. This is to hard to explain on a site like this. GOOD LUCK RDJRP
Anonymous
  • 507 Answers
  • Posted on Mar 07, 2009
SOURCE: How to replace Inner Tie rod on 1994 Chrysler Town & Country?
222,000 miles? that's a good vechile so far! anyways, do some price checking. new rack and pinions come with the inner tie rods. so if it's like 50 more for the whole assembly, i would but if not, it's up to you. i've changed some rack and pinions on vechiles that were under 150000 due to major leaking. and if you put just new rods in, if it dose start leaking later, you'll get new inner rods again with new system you'll just be paying labor and alingment charges again. so again, my OPINION is if I'm going to keep it for a while and if it's COST effective, just to do the whole unit.
Anonymous
  • 54 Answers
  • Posted on Mar 22, 2009
SOURCE: 99 windstar leaking power steering fluid
all the boot does is keep dirt from getting to the lip seal if its leaking youl atleast need to replace seal and boot i think on that model youl need a specialty inner tie rod tool to remove before you can get the seal out. if it was me i believe id replace the whole rack if you plan on keeping the rig long hope this helps please rate me thanks
Anonymous
  • 19 Answers
  • Posted on May 11, 2009
SOURCE: leaking hose in between power steering pump and rack and pinion
I agree with snowboard. Another name for the line wrench is "tubing wrench". It looks like a common boxed end wrench with six "points" or places of contact inside the boxed end but has a slot cut in it so it will slip over the metal tube part of the hose. Using this type of wrench you are less likely to "round off" the shoulders of the tubing nut. You won't be able to have the hose fixed. Well, you CAN, but it's much cheaper to buy a new one. I believe they're around $20.00 or so.
If the nut is recessed or some sort of wierd shape, try going to the dealership and talking to a mechanic. I've talked them into renting me a specialized tool. Some of the larger auto part supply stores also rent tools for a small fee. I think what you will need is the tubing wrench. Spend a few extra dollars and replace both hoses while you are getting greasy. That way you won't have to bother with it again for quite a while.
Anonymous
  • 23 Answers
  • Posted on Aug 29, 2009
SOURCE: replace front wheel bearings 99 ford explorer
not press fitted, standard tapered bearings, if 4X4 it is a little more involved, just dont misplace any of the smaller parts and you will be fine.
Testimonial: "thanks for the speedy reply and also for the right advice."
Lots of shaking from side to side.
Could be a bad tire ( or bent rim Have balance checked), ball joint, idler arm, wheel bearing, steering tie rod end or defective rack and pinion unit. Lift vehicle about 1 inch off ground ( do each side independently) Use a pry bar and pry from ground up and down on wheel. Much play? bad ball joint. With both hands, try to move wheel side to side. Much play? could be a tie rod end or bad wheel bearing. Visually check play of steering arm into rack and pinion unit, more than about a half inch play, bad rack and pinion unit. Try to move back and forth with hands top and bottom. Much play? Bad ball joint or wheel bearing, verify visually that it is ball joint moving, else it is the wheel bearing. Manually check for play in each joint in steering control rods from steering knuckle all the way through each rod where there is a joint. Replace the one you find excessive play in. Check mounting studs for sway bar for loose fit, deteriorated rubber bushings or a crack / break in the sway bar. Replace if needed. That's about all I can think of unless it only happens when applying brakes, in which case it could be a warped rotor.
Starter makes grinding noise when starting car. Sometimes it does no engage to start the car. Have replaced the started twice in the last year on my 1996 Nissan Sentra GXE Auto Trans.
check the condition of the teeth on the ring gear of the engine. They can become burred and cause improper engagement of the starter pinion. Check the adjustment of the pinion action.
2answers
Squeaking noise right front ?
not sure what type vehicle we're talking about here, although you can lube up the rack and pinion or grease up your upper, if so equipped, and lower ball joints.
1helpful
2answers
I have a 99 ford explorer and there is a grinding sound that is coming from the passenger side that is constant when i drive and it isn't the brakes
4x4 ? how many miles ? jack front wheels off ground and rotate by hand feel for the grind, bad wheel hub bearing? check brake rotor dust shields, If high miles possibly front carrier or pinion bearing. Just replaced front , rear , and transfercase bearings on my 98 with 193,000 mi. And yes,they were all bad $500.00 did labor myself. did rear first as it was humming, week later grind and hum coming from front, then couple days later transfer case was also whinning,humming, good god what a project all that was but today its great and quiet.
2000 Silhouette: loud grinding noise mechanic says its in the rack ...
have the front wheel bearings checked. they tend to wear out after 120,000 miles
7helpful
3answers
How do you change rear wheel bearing on a 2004 nissan sentra
Yes it is as easy as it looks. If you had the tire off and figured out that it looks easy, you shouldn't have much problem.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
