Question about Emerson Televison & Video
Need a fuse for my TV
Fuse is on the mainboard near the power cord. Number on the fuse is T8AH250VP. Just need to know a good place to buy parts - tried Radio Shack. Fuse is ceramic.
    New Friend:
  • 43 Answers
Yes , this 8 amp fuse , just buy the slow blow fuse but most of the time when this fuse is bad is because you have another problem on the power supply
Posted on Mar 05, 2012
4 Suggested Answers
6ya staff
SOURCE:
diodeic
SANYADE OMOTOLA
  • 1622 Answers
SOURCE: I have a Panasonic TH-50PX75U Plasma 50" tv. The
All you need to do is to open the back cover of the television to check for burnt transistor , this is always the problem , for you to fix this it require a basic knowledge on electronics,
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help out in solving the problem
Posted on Dec 19, 2010
Anonymous
  • 1077 Answers
SOURCE: 42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Posted on Jan 19, 2009
circuitworld
Circuit World
  • 335 Answers
SOURCE: owners manual and power cord
You can find them here: http://www.eserviceinfo.com/equipment_mfg/Akai_2.html
Posted on Feb 11, 2009
Will not power up
If you have a direct power cord attached to the TV, try another cord like it and turn it on. That rules out the power cord, unless the power fuse at your home fuse box was flipped, or the power fuse to the TV was blown. Sometimes a Power surge or failure trips fuses or blows a fuse; so check them first. If all the Fuses or Circuit Breakers are working just fine, then the problem is more serious. The condition may now relative to either the Picture Tube and/or Projector Tubes, the power transformer, or damaged mainboard of the appliance. Any of these mentioned herein need a professional technician to check the circuitry for faults.
Dec 22, 2013 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Where can i buy the ceramic fuse for my toshiba flat screen?
That model uses a e.t8ah250vp fuse and they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=316
The fuse is located inside on the power supply board.
Mar 27, 2013 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
Dash light went out, but all other lights are still working, don't know what wrong? Maybe a bad switch to the dash? Or fuse? Help!
Check all your fuses, one at a time with a continuity tester. Replace each fuse before you remove another fuse so you will not put the fuse in the wrong place. Also, if you find a bad fuse which you can purchase at an automotive parts place, make sure you replace the bad fuse with the correct amperage fuse. Do not go up on the replacement fuse amperage. The amperage number is on the fuse handle. You can buy a very inexpensive continuity tester at radio shack and they will teach you how to use it. Good luck.
Dec 03, 2012 | Cars & Trucks
Philips 42pfl3704d/f7 No power at all
its definitely the fuse. you have to go to the phillips website and type in your model number to get the right fuse. I went thru 3 different fuses and they all blew right away. phillips website sells the right ones 5 bucks each. Get it here and it will save you trouble trust me.
If nothing happens no light or sound when you plug it in to the wall it is definitely the fuse. mine was a T8AH250VP. You have to be sure to get that exact fuse. every letter exactly like that. there are a lot of similar fuses that will blow the moment u plug it in.
Hope this helps took me a month to figure this out. I was going to buy powerbaords for no reason. fixed my 42 inch phillips for under 10 dollars. couldn't be happier. Also always run your tv threw a power ack. If you plug directly to the wall your fuse will blow frequently.
Sep 23, 2012 | Philips 42PFL3704D LCD TV
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
Customer has lost his power supply cord. where can he purchase another cord. power cord is three prongs.
  • Hi, I can help.
  • For the Radio Shack TRC-447 this is just a standard 3 PIN DC cord. Many CB's use the same cord and they are interchangeable. Some Cobra, Uniden, Radio Shack use the same cord. Texxcomm is a great place to get parts from.
  • If you have any coimmments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 07, 2011 | Radio Shack TRC-447 CB Radio
My Directv H21-200 will not power on. Even after leaving it unplugged for a while. I need to know if there is a fix or if it's fried.
Take the unit aparts,the power fuse at near the a/c power supply cord.Check for the power fuse.If the power fuse it is dead,replaced it,u have a 70%-80% the unit will work again.If the unit power fuse it is good.Than the unit it is fried,it could be anythings are dead on the unit PCB board,now u must have great electronic skills and troubleshooting skills to find out where it is and replaced it electronic parts on the unit PCB board.Require alot of skills at this points.Not worth the effort.It time to buy a new one.
Apr 26, 2011 | Directv H21 DTV Receiver
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Where do u find the fuse in the mitsubishi ws-55513 55in. by the power cord???
Follow the power cord into the back of this TV. You should find a small glass fuse near by. If the fuse is still good, chances are real good that this TV can still be saved. The biggest problem with this TV is the convergence board, which has many, many, many bad grounds that need resoldered. No parts are needed as yet, just some good old fashion rework on the convergence board! Thanks for asking and show a few hands of support!
Feb 21, 2011 | Mitsubishi WS-55513 55" Rear Projection...
Why doesn't unit power up when power button is pushed? Checked outlet and is plugged in.
Take the cover off the unit to look at the fuse...it looks like a little glass tube and will be near the power cord input....you should see a little wire element inside that must be all the way across the tube, otherwise it is bad and will need to be replaced....these fuses are available from places like Radio Shack....If the fuse is good then there is probably a problem in the power supply circuit that will need to be troubleshooted by a service tech
Jan 16, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
Televison & Video Logo
836 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
