I installed a new toner cartridge but my printer still says no cartridge. I have unplugged, reinstalled, let cool, reinstalled my printer and nothing works.
HiTry going to you're control panel...click on printers and scanners...choose you're printer....Do a maintenance check on it..there should be an option to do this...Click on clean printer head, nozzles and alignment..Once these checkers have been done try printing a test page.I hope this works for youRegardsMichelle
SOURCE: dell 944 photo all in one printer
this is susanirene,please let me know where to go to get the answers I need?
SOURCE: MFC-240 shows no ink cartridge
Hi all,
I had similar problem, i.e. MFC-240 printing was "forbidden" even if one cartridge was out of ink. This did not make sense if I wanted to print black and white but only cyan is out.
I read about taping the sensor bit of the cartridge to (fool the printer). My solution is instead of using tape (which could require some delicate work), I used liquid paper! Just paint over the transparent spot of the cartridge using the small little brush from the liquid paper bottle cap. Wait til it dried and plug the cartridge back in. It worked!
Jim
P.S.: I pulled the power after I finished printing to prevent its auto-wake (every two days or so) head cleaning job which used up internal ink (=expensive). The surprising rattling really annoyed me.
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hello marthafindsh,
try this link
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/002500/000055/faq002555_000.html?reg=eu&c=gb&lang=en&prod=hl4070cdw_all
please don't hesitate to email back if you have additional querries..
SOURCE: hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
SOURCE: lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
I took back the cartridge and got another one. I tried many things and still no results.
