Help, how do I close the front panel door. I was able to open now I can't close it.
On the sides of the panel, inside, is a spring clip that must be pushed down in order to lock the panel in place. One side at a time, insert a flat head screwdriver into the side of the panel (near the top) and pry down the clip...once it's pushed down far enough, it will clear the lip so you can push the panel in and release the clip, relocking the face cover. Do the same to other side
SOURCE: leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
SOURCE: door won't close now
I can tell you where the door latch release is.
Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on towards the bottom) Once you have that panel removed, reach up just behind where you see the openings for the door latch. the black square hole and black round hol are all part of a larger door latch mechanisim. At the bottom of this mechanisim (cloest to where your hand will be) there is a "tab hanging off the bottom". Pull on the tab for a manual door release.
Please make sure if you found this solution helkful to make sure you rate it. Best of luck with it and drop me a note if you have any other troubles.
For
Doors not getting open with remote or key problem,there are help
links provided below.Click the link below to go through its
procedure and troubleshoot the problem:----
drivers side front door will not open from
inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will
not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door
locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car
Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control
Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not
working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with
Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace
Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will
not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
Car door will not close?
All power door locks not working ?
Repairing car Door lock Actuator?
Truck Door will not
close?
-----------Where is Cars Door control
Module located?
working?
-----------Door ajar light stays on?
Doors will not open
with Remote?
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html -------`-
--------Remote will not unlock Rear
door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html --------
--------This will help.Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
All power door locks not working?
Where is Cars Door control Module located?
Power door locks not working?
Doors will not open with Remote?
Remote will not unlock Rear door?
Central locking not working?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
For
inside or outside?
Car door will
not close?
All power door
locks not working ?
Repairing car
Door lock Actuator?
Module located?
working?
Remote?
How to replace
Door Hatch ?
Remote will
This will help.
Thanks.
