UNIT WENT DEAD WHILE WATCHING. HAVE NO POWER OR POWER LIGHT. HAVE REPLACED POWER SUPPLY WITH NO CHANGE.
If your tv is a plasma and you have replaced the P board,try dis connecting A5,A6 and A7.Then if you hear 2 clicks and the screen comes on with a white screen without hitting the power button,then the A board is bad.
If your power supply is new try to check the power cord..If you have a volt meter or multimeter range in AC..check the voltage input of your power supply it should have 110v to 240 volts depends on your electrical supply in your outlet..
If no voltage replace the power cord..Hope it helps..
SOURCE: PANASONIC TH-42PD60U
I had a similar problem where my TH-42PX60 would turn on but all controls were disabled. I could not change channel, input, volume or anything other than turning the TV on and off. I called customer support and they directed me to this site: http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/downloads1.asp to download a firmware update onto an SD Card. I inserted the SD card into the slot in my TV and powered it on. The update took about 3 minutes and I haven't had a problem since.
This is a link to the instructions to install the update:
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/Firmware/PDP/PX60/UpdateInstructions.pdf
SOURCE: Panasonic TH-42PD60U Wont come on..
hello, I went to the Panasonic web site and it said driver sos3 (SS energy recovery circuit) on the SS board. call 1-800-211-7262
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me.
Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Testimonial: "cool thanks alot"
power cord is fine. power supply has the 5v supply working
