When we try to turn the desktop on it sounds like its starting up, but the monitor stays black and the power button flashes 3 times and then goes solid for 10 seconds or so before flashing 3 times again, repeatedly. It's not responding to anything and won't turn on completely. Any ideas as to how to fix this issue? We were able to find out that the flashing possibly mean the desktop does not recognize the monitor as compatible but it's that monitor that came with the tower so we're not sure how this would have happened...
SOURCE: Apple PowerMac G5 Mac Desktop
Yes, that is a major factor. Because the files arent actually kept on the desktop, so when you boot it, the machine has to" remember" where that content is actually stored. You should also defrag the hard drive with DISK UTILTIY.
MAIN DRIVE/APPLICATIONS/UTILITIES/DISK UTILITY
You can also check the space left on the drive. It should state at the bottom of the window when that volume is selected. Or you can also click on it once and hit the apple and "I" key..
APPLE+ I also know as "get info" from the top file menu. If you do a considerable amount of downloading, or if you have a massive itunes folder and you are saving that to your internal drive and not an external, you operating system has to weed through all that information. If youre getting spinning beach balll as well, I'd recommend install more RAM modules.
Hope this helps, keep me posted.
SOURCE: My eMac doesn't like to restart after being put to
I know emacs have had there times and this might be the cause for yours as well. Do this: turn the mac upside down take off the memory cover from the unit using a screwedriver now you will see 2 round capcitors there check to see if there buldging at the top or leaking for the bottom. Now not all caps leak they just buldge. If this is the case you have a couple options here 1. repair it yourself 2. take the logicboard out of the system (a lots of work) and log on to www.badcaps.net this dude will repair it for $75.00 plus shipping Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: PowerMac G5 with dual 2.7 processors powers on but no video
There are seven diagnostic LEDs near the memory banks of this model: six in a tight line between the edge of the logic board and DIMM bank 1, and the seventh just underneath DIMM bank 1 and slightly more inboard. Please tell me which of these LEDs are on and I will tell you what they mean.
SOURCE: power mac g5 shows terrible
None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
