Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081" To program the BT Vision remote, instructions can be found at: http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
SOURCE: codes for tuning bt vision box to sanyo tv
There are only 2 codes for Technosonic. 0037 and 0556. I hope these help.
Sympton Problem Solution
Rolling Screen?
Black & White. PAL Video is selected in error. Click on the TV SYS button located on the DVD remote near the Power button.
Light to Dark Picture. Connection to VCR or TV/VCR combo. Unplug the DVD player from your VCR and connect the DVD player direct to your TV (bypass the VCR). If TV does not have audio/video plugs, or if you have a TV/VCR combo, you will need to purchase and install an RF modulator (available at most electronic retailers).
The light to dark picture? Condition is caused by the disc manufacturer's license encoding at the time of manufacture. It is not cause by the DVD102 player.
No Video. TV needs to be switched to the correct input mode. Your TV must be switched to the correct video input selection. You can only switch the TV to accept an outside video source by using the original factory remote. Locate the button on the factory remote that switches the TV input. The most common descriptions on remotes are: GAME, TV/VIDEO, A/V, VIDEO, INPUT or SOURCE.
Universal Remote Code. The code has not been published. The Universal Remote manufactures create the codes.
Region Error. Software issue. Return the DVD player.
Unit Displays No Disc Even After a DVD has Been Loaded. Defective unit. Return the DVD player.
Unit Displays Loading Even After Giving Adequate Loading Time. Defective unit. Return the DVD player.
Here is what I was able to find.
If not let me know and I will try finding more info
SOURCE: wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
[email protected]
SOURCE: LG 42LC2S - Remote control code
After many months trying to find the BT Vision code for my LG 32LC2D, i have just had success with 005 remembering to enter an additional zero after the remote has flashed three times, so you enter 0005.
Hope it works, good luck!
SOURCE: i need the remote code to work the volume button
good day if that remote you have the original on your tv , no need to search a code, code only apply when you using the universal remote. maybe your remote needs cleaning the board, so that all button will function
Not sure if mines f...ed but even wen I press tv or tv av it don't light up just blinks twice even after reserving remote I've tried the 0081 but no good even tried asda uni remote but seems to only do 3 coded tvs
Any other codes found for it e-motion tv think mines a 40inch 1080p
