SAYS offline, HOW DO I GET IT BK ONLINE?
This is a network communications issue, most likely. If re-booting the copier doesn't change it, try rebooting the switch or hub it is connected to. I have seen Kyocera's take several minutes to report they are online following things as simple as being out of paper or a jam. Repeatedly trying things may cause it to stay in offline mode longer. If you are certain all panels are closed, paper and toners are in place, etc. and there are no codes or error messages, the machine should eventually be OK. If nothing works, it may be your cat5 cable or the socket in the machine. If the machine was moved with the cable still in, and it got a hard pull, there could be damage on the main board connections to the cat5 socket. that is sad and calls for board replacement.
