RUNS WIDE OPEN BUT DOES NOT PRODUCE ANY ELECTRICY.
Hello, If your generator has sat for a long time, the residual magnetism in the field coil may have dissipated completely this will cause the generator to produce no electricity. If this is the case there is a fix that is so simple it will amaze you by how easy it is to get it running properly again. The process is called flashing the field and it is done with an electric corded drill. Here is a link on how to do it. http://www.perr.com/tip16.html I hope this helps. If my solution works for you would you kindly give me a positive rating. Thank you, Michael Burke
Deseo seber el numero de parte de los soportes de generador y soporte de bastidor
tried this but it did not fix the problem.
