Question about Hoover HTC243 Top Load Washer
Hoover 500MD occasionally doesn't spin
First of all thanks to anyone who replies with suggestions.
I have a Hoover 500MD 5KG top loading washing machine.
Occasionally it will go through the complete cycle without spinning, other times it won't do the spin dry at the end of the cycle, but will spin throughout the rest of the cycle. Then sometimes it works fine.
Any suggestions as to what I could check would be appreciated.
6ya staff
SOURCE:
Anonymous
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
Anonymous
  • 69 Answers
SOURCE: How do I remove the agitator in a Hoover 500MD
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Posted on Aug 25, 2009
drallim
  • 4088 Answers
SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Posted on Oct 20, 2009
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
Anonymous
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
john_cross
  • 6277 Answers
SOURCE: How to remove lint from
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Hi, my 5kg hoover tumble dryer is having difficulty operating with a 5kg load. It doesn't spin very well now, is the motor wearing out? Bearings? are there any grease points I can get to? Please advise....
is it belt driven one?....if so maybe the drive belts need adjustment and some lube squirted on the bushes/bearings could help.Make sure you are not overloading it....common problem.
Jul 21, 2010 | Dryers
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Machine washes o.k. but does'nt spin dry (hoover soft wave auto - washer 1000 )
If you have not already done so, I suggest you remove the motor, and check the brushes for wear.
Please rate my solution.
Thanks.
Oct 08, 2009 | Hoover AAA160 Front Load Washer
How to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Jul 12, 2009 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
217 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
