Hoover washing machine gets stuck between program 9-10
Hoover AC120=001 gets stuck between program 9-10 sometimes not reaching temperature and sometimes going on to boil, have changed thermostat but still sticking
  • Richard Gillett Mar 11, 2012
    Thank you for this. It fits with our thoughts.
    Top Expert:
  • 867 Answers
You have a fault inside your timer, These can be repaired but due to the age of the machine it may or may not be worth while repairing, The machine is sticking due to a contact issue somewhere inside the timer.
Posted on Mar 09, 2012
2 Suggested Answers
6ya staff
SOURCE:
john_cross
  • 6277 Answers
SOURCE: hoover performer 1200 ac120.what size is the
Have a look at the manufacturer's panel, probably on the back- it might give you an indication there- or your manual?
Just in case-
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
Another possibility would be to go onto the manufacturer's web site DIRECT to see, OR your (intended) vendor's site?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Aug 26, 2011
I have the Hoover performa 900 washing machine but still works great but sometimes I just want a quick wash! I'm sure my machine runs over an hour, i just need a 20 minute quick wash? Pls help
A Quick Wash program is normally 30 minutes, often called a Half Hour Quick Wash. It is a short wash, three rinses with two spins. Unfortunately your machine doesn't have one.
hoover performa 900 washing machine manual Google Search
Jul 01, 2018 | Hoover Washing Machines
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
Apr 12, 2014 | Siemens Dishwashers
Hoover softwave not doing anything except clicking
It sounds like the rotating program controller has failed. It is telling other parts of the machine to do things as part of the wash cycle and the signal is not reaching them. This is an expensive part to replace. Get it fixed under guarantee if its new. If its old replace it, but do not buy a Hoover, they are very cheaply made and fail a lot. If you want a cheap one buy a Zanussi.
Dec 20, 2013 | Hoover HC6 110M Front Load Washer
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
The pump on my hoover washer hnf7148 has been changed but the problem persists. Water is still in the drum and it will not drain away. The control panel when the machine stos shows the door closed with...
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Jun 24, 2009 | Hoover Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Hoover top load washing machine
make sure thers nothing stuck in the pump and the pump is not faulty.somtimes a coin can get stuck in the drain hose causing it to not drain intermittently
Dec 21, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
