The mixer uses unbalanced TS connectors You need these connectors to hook up the speakers. Below is a link to the manual for the mixer.
link:
SOURCE: brand new mixer pmp3000 and two brand new speakers
Make sure the slider switch is set to the correct mode.
The TRIM controls must be advanced while the sliders are at 70%.
A common problem is to MISTAKENLY plug 1/3 inch input cable into the Effects Insert jacks instead of the inout IF you use 1.4 instead of XLR inout.
Make sure the channels of interest are NOT muted!
Testimonial: "Thank you very much! all the best!!!"
SOURCE: hi i have 2x ev sx300 speakers (speakon) and 2x
Yes, you can put two 8 ohm speakers daisy chain per side MAX. The Speakon should have ONLY two wires on the +1 and -1 terminals unless you are using bridged mode which is NOT applicable in your configuration of speakers. Also be careful is you use any 1/4 inch speaker plugs in the sytem as the SLEEVE, not the TIP of channel A is the "hot" lead... get this to ground someplace and goodbye amp.
SOURCE: Will a Behringer UB2442fx-PRO run
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
