A
Anonymous Posted on Mar 08, 2012
Printer go to www.kodak.com/go/alosupport(3806) comes up on printer screen what can I do.
Printer Error Go to ww.kodak.com/go/alo support (3806) comes up on my printer screen and my printer will not work .
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 15, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
700
Points
0
Unser drucker geht nicht mehr
5 Related Answers
Anonymous
  • 236 Answers
  • Posted on Oct 03, 2009
SOURCE: Kodak Easyshare 5300 printer error code 3806
YOU HAVE TO REINSTALL YOUR DRIVERS FOR KODAY 5300 PRINTER.
GO TO CONTROL PANEL AND CHOOSE ADD/REMOVE PROGRAMS AND UNINSTALL DRIVER AND REINSTALL DRIVER AGAIN, YOU MAY GET SOLUTION.
Anonymous
  • Posted on Feb 13, 2009
SOURCE: Installation of printhead on Kodak 5300 All-In-One printer
installing the new printhead is pretty easy. there is a button on the upper left of the printhead. just push it an the old one will pop out, when you put the neew one in make sure to push it until it clicks
Anonymous
  • Posted on Jul 30, 2009
SOURCE: Error code 1-2036 on Kodak ESP3 printer
To askmeprinter: following your recommended steps does fix the problem TEMPORARILY. The scanner will work after being re-installed, but will cease working again after going into sleep mode.
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Nov 08, 2009
SOURCE: How do I delete ''http:/www.rulesforuse'' from printer?
Unplug usb. Uninstall printer driver. Restart printer. Plug usb and turn on printer. Reinstall driver.
Anonymous
  • Posted on Dec 31, 2009
SOURCE: kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
What is error code 3806?
Error Printer error 3806 3807 3808 3809 3810 or 3811
Kodak does not say what the error is but they do show how to deal with it.
1helpful
My kodak esp 6100 keeps on showing error code 3806?
Disconnect power cord, let it set 30 sec, reinstall cord. If problem still there pull out the printheads and reinstall, may have to do this a few times, if problem still there may need printheads.
Kodak ESP 3250 says Printer Error. Error Code 3806
According to the Kodak website, you should follow this procedure:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn on the printer, if necessary.
If the error continues:
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
  5. If the error is displayed, contact Kodak
Error code 3806
From Kodak support:
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Error 3806 thats all it does
To resolve this error:
  5. If the error is displayed, contact Kodak.
Error code 3806
Kodak error codes are usually generic, I have found for most of them, if you disconnect the power and wait a few minutes then plug it back in to a power source, the printer resets itself.
2helpful
2helpful
ERROR CODE 3805
You really need to call kodak support for this one
because the edge sensor of the printer is not
working thats the meaning of
3805 they will replace the printer
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
