Kenmore 22422 Top Load Washer Logo
Posted on Nov 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 70 series. knob -timer-button
While turning around the cycles the button got out from the screw. It is black plastic knob 2" w/ metall cenrum. I could not understand what happened. The broken button is not fitted to the screw when I tried to reuse. It seems some metal threads inside broken knob. But I can run cycles by my hand. Should I buy new knob? Can I replace it at home by myself? Please, let me know ASAP. Thanks.
Anonymous
Level 2:
Scholar:
  • Expert 60 Answers
  • Posted on Nov 09, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
60
Questions
Helped
30849
Points
146
The knob is a simple screw on knob and the replacement part number is 3353309. Cost is 16.50. It will have a metal back as opposed to the plastic one you must have now. Shipping would Should you choose to order, follow this link:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
1helpful
How to remove the timer?
HERE IS A LINK TO YOUTUBE VIDEOS CONCERNING YOUR WASHER..... BUT I DIDNT SEE ANYTHING ABOUT A TIMER. I HAVE REPLACED KENMORE TIMERS....PULL OFF THE KNOB...
REMOVE THE SCREWS THAT HOLD DOWN THE COVER WHERE THE TIMER IS LOCATED.... ONCE YOU HAVE THE COVER OFF..... GET YOUR PHONE OR CAMERA AND TAKE A PICTURE OF WHERE ALL THE DIFFERENT COLORED WIRES ARE LOCATED...SO YOU WONT BE LOST WHEN YOU INSTALL THE NEW TIMER.
https://www.youtube.com/results?search_query=HOW+TO+REMOVE+A+TIMER+Kenmore+Series+70+Washer+Motor+387780
tip
How to access the start switch on a Kenmore 70 series dryer
The start switch on a Kenmore 70 series dryer sits directly behind the button you push in to start the dryer cycle, and it can occasionally go bad. Accessing this switch for repair or replacement is relatively simple; just follow the steps below. (These instructions were written specifically for the Kenmore 73742 heavy duty dryer, but they should apply to all of the dryers in the Kenmore 70 series.)
1. Unplug the dryer from the wall outlet.
2. Pull the dryer away from the wall so you have enough room to get to the rear side of the dryer.
3. Remove the rear access panel. This panel sits horizontally along the upper rear side of the dryer, and it is held in by six slotted screws. Put the screws aside, but do not lose them.
4. The start switch is located on the far left side (as you are looking at the rear of the dryer). It is a small black box with wires coming off of it. Disconnect these wires, but note which wire connects to which terminal for when you reattach them.
To remove the switch and button assembly as one piece, you'll first need to remove the knob from the front of the dryer. You should be able to pull the knob straight off, but if it's tight a pair of pliers might help. The round white plastic piece might come off with the knob; put it somewhere safe so you don't lose it. Then go back to the rear of the dryer and pull the black plastic tab (sticking vertically away from the switch) toward you to release it, and rotate the assembly clockwise until it pulls free from the panel.
To remove the switch from the button and housing, use a small flathead screwdriver to pry the switch up. Two of the four sides are tabbed; pry these two sides up to release the switch. There is a spring that sits behind the start button -- be sure not to lose this spring.
1helpful
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Kenmore 70 series stuck in rinse cycle, won't drain
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
Kenmore 90 series wont advance to next cycle
Yes, most likely but to be sure you can check voltage at the timer assembly 2 small black wires coming out of the timer.....
2helpful
1helpful
My kenmore 70 series washer timer stops on the rinse spin cycle and then the timer doesn't move any more, how do I replace the timer?
2answers
My Kenmore 90's series washing machine will not move into the spin and rinse cycle unless we use a screwdriver to put pressure on the switch. Does this mean the switch is bad?
The timer you have has a bunch of small gears inside. The case is made of plastic. Yes the timer is most likely shot.To get the timer off you grab the black plastic rod in back out and this releases the knob. Then you can access the screws holding the timer on.ec1c7f4.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Alexander
vince
