Hi want to change to all regions any help would be great regards duke
If you are limited by the dvd region code, you can get a dvd copy without region code so that you could play it on your dvd player, You could tryLeawo DVD Copy to remove the dvd region code and get a dvd copy.
This model is not crackable to make it region free. There were region free models available to some markets but if not region free then no way to make it region free.
SOURCE: MULTI REGION
1. Switch on the DVD - without and DVD in it.
2. When "no disc" appears press the following sequence of numbers from the remote control: 9735
3. Choose the region (0 is universal)
SOURCE: LG DVD PLAYER DV8621P
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9
Instructions for changing region code appear on screen,
Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
SOURCE: Region Code Breaker
I have manage to play Region 2 DVDs on a the Region 1 that I purchased.
I starte by opening the tray and keyed in 98790. Initially this
didn't work. Following this I repeatidly pressed 9 until it came on, it soun
ds bizarre but it did the trick.
Regards.
SOURCE: Multiregion DVD region code for Samsung V6800
This is not promised to work but a known hack for your model of DVD player is...
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
People have reported a problem with the codes given however another was posted (57538) try that one to!!
Hope this works post back and let me know. Thank you for choosing Fixya!
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
hi this is a LG BD660 3d blue ray player there got to be a way to change to muti region some how please thanks to those who have tried regards duke
