E9 & E2
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor.
(remove pressure tube and blow through it to make sure it is clear first)
ERROR E2 PROBLEM
Have daewoo wash machin DWD F 1211 show E2- error cheng the level sensor and fixed error
E2, error in my machine, wS caused by coins in my pant pockets & repaired by removing those coins, now wAter flows freely
