Cannot play Iron Man blu-ray disk. The player says it's invalid.
SOURCE: WILL NOT PLAY IRON MAN OR KINGDGOM OF HE CRYSTAL SKULL, BUT IT PLAYS ALL OTHER BLU-RAY DISKS
Go to the wed site and download the latest Firmware update to your computer. It downloads as an image file. The use a disc burning software like Nero or Cyberlink's Power2Go and go to "Burn Image to Disc" and burn it on a regular CD-R. Insert that to your player after turning it on and let it do its thing, it will take a while so don't power down thinking it froze or it will mess up your player.
After the update is done, your player will re-start. You should now be able to watch the latest movies.
Be Warned! Even newer movies might have issues playing. That's normal, just give time for the manufacturer to release an even newer Firmware update to play them. Just one of the things we have to live with for the sake of 1080P.
SOURCE: sony blu ray player
Hello Thank you for choosing FixYa.com for your answers my name is David.
If it takes it a while to read sounds like one of 2 things or a combonation.
your reading lense that reads your discs may me dirty or you may have dusty
or damaged disk. most likely your machine is dirty I would go to your local store
and ask them for advice on the best type cleaning disc for the blu ray player
walmart has decent prices for that sort of thing good luck and thank you again for choosing FixYa.com
SOURCE: our blu-ray disc player bdp-s300 won't play newest blu-ray
You will need the following:
1) Internet connection
2) Wired router
3) long enough ethernet cable to reach from your blue ray player to the router.
Step 1:
Eject any disks and turn off the blu-ray player by unplugging it.
Step 2:
Attach the ethernet cable to the router and the other end to the ethernet port on the back of the blu-ray player.
Step 3:
Turn on the blu-ray player and wait for it to load all the way.
Step 4:
Using the remote, arrow over to the left to "Setup", the up to "Network Update".
Step 5:
After the unit updates and restarts, repeat until it tells you "Already Updated".
That should help you play the newer movies, and even some of the older ones.
SOURCE: Some blu-ray disks play on the sony bdp-s300 and
Cause walmart has parental discs. Some sort of censorship version. All there music cds delete or beep/blip the profanity out, so im pretty sure they get their movies with a certain level of parental control embedded. Make sure your parental control level on the sone BD player if set to play all. Basically no parental regional restrictions. Hope that help. If that doesnt. I suggest just not supporting Wal-Mart. They are NWO associated. And everything you buy there no matter hw insignificant have RFiDs embedded into them. Just a little FYI for ya. Google it. Its creepy stuff.
