SOURCE: Bosch exxcel wvt1260
I'm not familiar with this model of dryer, but I understand that this is a vent less condenser model(?). If there is a condenser tank on the dryer, you may have to empty it from time to time. The excessive steam could be a sign that you have a tank that is full. I don't know if this will be of much help to you (I hope it does). Double check your owner's manual to see if it mentions anything about this in the care and use instructions. Take care.
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
I have a Haire combo unit. (washer/dryer) The dryer is a condenser type. I had a this problem with the dryer part of my unit. It was still under warranty at the time so naturally I called. When the tech came out he discovered that the heating element had melted the fan all over the blower elements. this problem could have been fixed, however, Haire came out with a newer model and couldn't get the parts anymore because they weren't making them anymore. Needless to say that totally sucked. But, at least the washer still works great. Upon doing a little research, I discovered that most condenser dryers do get too hot to support one or more of thier internal elements. I would not get another dryer like this without asking about this problem and if there has been any rectification of this issue and how so.
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
