Question about Hoover Nextra HNWL 3126 Front Load Washer / Dryer
Bearing failed in Hoover HNWL 3126S
Which way does the drum come out? from above or below? to change the bearing, It is the bearing as the noise was unbearable on spin, and now the doors open (and the smoke cleared!) the drum lifts up and down and viewed from the rear the pulley moves a good couple of mm. Which bits should I have to remove to change the bearing?
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Posted on Jan 04, 2008
danbhoy
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
Anonymous
  • 57 Answers
SOURCE: We are looking for a Programme Selector for a
hi there my best advice is phone gias in rochdale go to gias website for number when you ring tell them you repair washing machine so you get a trade price
Posted on Jun 23, 2009
Anonymous
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: hello hi, could u please tell me how to find the
Hi .Go to the following site for the information you require.
WWW.HOOVER.CO.UK
Click on AFTER SALES SERVICE in the nenu
Then click on INSTRUCTION MANUALS in the menu
Then click on LAUNDRY
Then click on WASHER DRYERS
Then enter your model number in the box .
You should then be able to download the instructions for your model .
Posted on Dec 23, 2010
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Front load kenmore 11047511701 makes a high pitch noise on spin cycle
this sounds like drum bearings wearing out,,,,open the door and check if thee is any lift in the drum only lift it a little if there is this is wear in the drum bearings,,,also check the motor bearings by spinning the drum by hand if it screems its motor bearings
Dec 01, 2010 | Washing Machines
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
My Hotpoint BWD129 washer/dryer has got noisier and noisier during the spin cycles. It is now so loud it is unbearable to be in the same room as it and it rattles anything off the worktop nearby. Any...
This is most likely the drum bearings failing.
Drum bearings normally last a long time (10 years or more isnt unusual), but quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Nov 13, 2009 | Washing Machines
Hi, there i a knocking noise during the spin cycle on my hotpoint aquarius 6kg wma56 washing machine?? How do i fix it?
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Nov 12, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WF430 Noisy on Spin Cycle
Hi.
It could be loose balance weight, or worn drum bearings.
Remove belt and spin drum by hand from the inside, if you can hear a rumbling noise, or any noise, or it feels stiff to turn then the bearings have failed
If it is under 5 years old, then it should still be under warrenty provided you did not buy it from Comet or Currys.
If it is balance weight, you will be able to feel movement, there is one at top and one at bottom of m/c.
Nov 23, 2008 | Hotpoint WF430 Front Load Washer
Hoover Nextra HNWL 3126 Front Load Washer / Dryer Logo
62 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
