SOURCE: I have an olympus stylus
hi there
you need to press the scn button (just to the left of the speaker) and keep pressing until you get to movie mode then press the play button to select it (Just underneath scn button) and then you should be o.k.
hope this helps
beergut707
SOURCE: Self Timer
Go to this web site find your camera select it. Then go to support then download the manual.
http://www.olympusamerica.com/cpg_section/cpg_digital.asp
Good Luck
Please rate FixYa!
SOURCE: adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
