My mobile router stop the light on wifi and lan, i cannot connect to either LAN or Wifi? please help me thanks
Sometimes, you may just need to update the drivers for your adapter, suggests PC Mech. If you cannot connect to a home network, move your wireless usb wifi adapter closer to the router. Other radio frequencies, such as cellphones and microwaves, can interfere with wireless signals.
SOURCE: I have a 2640b router failure
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
SOURCE: no power led, wlan led blinking
remove the power adaptor for about 5 min. and plug it again.
reset the wifi router to its original setttings (factory default) and configure again the settings.
check your network card disable it and reenable it again
same thing with your wireless card
SOURCE: Not able to configure wifi router
im having trouble with wireless connection it says i have full signal but is not connected
SOURCE: Unable to access my Laptop on My Network from my
To enable file sharing you need to follow the below steps
I moved this to networking for better exposure. I'll give you some basic tips, but it's generally pretty simple.
Turn off any firewalls for debugging. If the firewall is the problem, you'll have to configure it to allow access to "trusted zone" addresses. Note that some firewalls must be completely uninstalled to stop them from affecting your networking.
PING each computer by IP address, and if successful, PING by name. You can obtain the IP address of a computer by opening a command prompt (DOS window) and typing IPCONFIG. This should work for any Windows version.
All computers should be in the same workgroup for computer browsing to function properly. File & Print Sharing has to be enabled on any computer you wish to share files or printers from. You also need to actually share the resource in question from My Computer, right click on the drive/printer/folder, and select sharing.
If you encounter difficulties accessing computers that are visible in Network Neighborhood, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
While the default NetBIOS setting is correct for normal network configurations, it's possible for it to be altered, and it costs nothing to make sure it's correct. NETBIOS over TCP/IP must be enabled for normal network browsing.
Let me know if this will help
SOURCE: wifi problem of DIR-300 dlink
Hi all,
Good day,
I have purchased a DIR-300 Dlink router. the connection is OK via LAN. the issue is the wifi I cant receive IP from the DHCP server of the router.
Kindly assist.
Qureshi
Already update still no light on wlan still can't connect to wifi please help.. thanks
