I cant use any sim,..keeps on looking for restriction code...plss..help me...tnx..
SOURCE: 6300 restriction code
A word of advice dont publish your imei somebody can mess it up like a pie for all seasons.
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generator software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
SOURCE: Nokia 6500 slide - RESTRICTION CODE
hi,
I have Nokia 6500 Slide locked to UK Orange Network.
IMEI Number is 352027027919833
Kindly help with a Unlock code.
Thanks.
CAISER NOMAAN
Hi, I need your help for getting undo code for the following mobile:
Nokia 6500s-1
V04.81
RM-240
(c) Nokia
Varant:01.06
IMEI: 353076027844417
Language: V 04.81
Service by United Kingdom-3
My contact mail: [email protected]
SOURCE: Restriction code for nokia 2630
hi im josh a mobile phone technician in cebu phils.may i help you? Friend your mobile phone is restricted in other sim rather than smart because the phone is set or locked to only one network wich is the SMART.in our term your phone is not openline. Friend to make your phone open line you need to go to SMART provider and ask to openline your phone.or you need to go to moble phone service center around you and they will do the job.i cant help you online coz it needs software and cable wires to do the unlocking.that would take a short time to unlock just about ten minutes so if you go you just wait your phone and donot leave it. thats all friend hope i helped you.good luck
