I am trying to hook up a vizio blu ray player to my sony bravia KDL-32XBR1 tv. I connected the TV to the BlueRay using an HDMI cable. Instructions say to select HDMI input but that is not an option that appears on the Wega Gate. Any ideas?
SOURCE: SONY BRAVIA 32" XBR LCD TV KDL-V32XBR1
What about the Led, it shows blinkig light or just dead . if no blinkig at all could'be power supply fuse and or the powers upply board
SOURCE: Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
