All menus are in Japanese. I can get to settings but I have scrolled through each and every menu trying to change the language to English but haven't been able to. Can you specify the exact steps I need to take to change the language to English?
SOURCE: Change Language to English
Go to the settings (equalizer symbol).
Than go down to the 5th menu item (language, sprache, langue, lingua, la lengua,Taal ...)
The first one should be english.
SOURCE: Can't change language
In order to change your language back to English or whichever language you prefer. Please go to Settings (which is the icon with 4 bars & 2 bars are moving up & down)....select Settings to go to submenu, then scroll down until you see FM xxx, then the line above FM xxx should be your language menu. Select it and it will bring you to the list of the language and you should be able to choose your preferred language again. Hope this helps
Please rate accordingly
Thank you
Computerrep
SOURCE: need to change language to english
Find the menu, look for settings, look for the language setting.
If sony nw s750 how to back langues english ang i cant read japanese langues
