How can I reset the printer back to factory defaults. A tech set the passwword and left the company.
SOURCE: how to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
SOURCE: I need to reset the Key Operator Password on Ricoh 1515MF
Look about the Service Manual (for technican)
souch informations you will find there:
http://fileshare.eshop.bg/downloadsm/33807/Ricoh_1515.html
or there:
http://www.eserviceinfo.com/index.php?what=search2&searchstring=aficio+550-650
SOURCE: ricoh aficio 1035 factory rest now unable to get into settings
Press.
and # both simultaneously by but of 10 seconds until it is extinguished,
this restores the values of factory, with luck this had to solve it.
SOURCE: i have a ricoh ft5535 photocopier.. the problem is
This is not related to factory settings. This have everything to do with general service and consumables, so do optical cleanup and replace drum, cleaner blade, fuser rollers and corona wires.Developer must be adjusted by sim 65 then you can do exposure setting with sim 48.
SOURCE: need to reset my Ricoh
Tis printer is designed not to be reset. The only way is for a Ricoh Engineer to fit new boards. I was told this by Ricoh today when I phone for advice on the same thing. Apparently they sellthese to the FBI who demand security (Souds like b******t to me.
