HOW DO YOU CLEAN THE FILTER
This is a self cleaning dishwasher. This means the chopper inside the wash pump assembly crushes all the food waste and pushes it down the drain.
If you are having dirty dishes then the chopper is choked and needs cleaning.
You will have to open the dishwasher wash pump assembly to get there.
See this diagram for details. The chopper is item 6. I am assuming you have cleaned all the wash arms holes etc.
I found that the filter is not the problem. After reading some posts what I think has happened is that the impeller is broken because no water is spraying up to the three rotating spray arms. The dishwasher fills and pumps out correctly but no water sprays from the arms. How do you replace the impeller?
