SOURCE: Toshiba Satellite L505 series laptop would not open windows
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Thanks
SOURCE: My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
