Question about Kodak EasyShare C613 Digital Camera
Kodak c613 need usb driver for kodak c613 camera visited kodak website but download of easyshare 7 downloads small file then downloads rest of software emailed kodak asking for software as a zip but they said this was not possible computer with c613 camera has no interenet and no kodak cd just need driver for cam but if i need to use easyshare thats ok although not impressed with this software
  • keitht1958 Nov 21, 2008
    same as all others downloads it sends 1.6mb file called easyshare.exe and when you run this then it downloads a 45mb update but i need the file to transfer to a pc with no internet
  • Anonymous Mar 23, 2014
    i have windows 7
  • 5 Answers
Try Easyshare 6. 45MB d/l though
http://www.kodak.com/global/en/service/downloads/dln_ekn030260.jhtml?operatingSystem=windows_2000&downloadLanguage=en
Posted on Nov 20, 2008
Hi, where do I found the software driver for Kodak EasyShare C613 Digital CameraC613 for Windows 7. Thanks Susanne
http://support.en.kodak.com/app/home/selected/true
You might want to consider NOT using a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 10, 2011 | Kodak EasyShare C613 Digital Camera
I lost the software for the c613 camera how do i download it to my comp
Keep in mint that C613 works with KODAK EASYSHARE Software; select your right Operative System for download: Support.en.kodak.com
Also, you can find this alternative download site: Drivers-Kodak--EASYSHARE-C613
Hope this helps (remember to rate and comment this ansrwer).
Jun 27, 2011 | Kodak EasyShare C613 Digital Camera
I need kodak easyshare c613 driver please
Hi muratkaradag ,
Please find the links from where you can directly download the drivers for your camera.
Make sure that you select the proper operating systems that you use so that the relevant drivers can be installed.
For kodak easyshare c613 drivers for WINDOWS operating systems , please visit :-
http://support.en.kodak.co.in/app/answers/detail/a_id/28047/kw/Easyshare%20C613
For kodak easyshare c613 drivers for MAC , please visit :-
http://support.en.kodak.co.in/app/answers/detail/a_id/28049/kw/Easyshare%20C613/selected/true
Hope this helps.
May 11, 2011 | Kodak EasyShare C613 Digital Camera
I lost the software disc for my easyshare c613 can you help??
Here is the software for the camera:
EasyShare Software
  1. Verify that your computer meets the system requirements. NOTE: APPLE QUICKTIME Player is required for some software features. Visit APPLE to download the latest version of the QUICKTIME Player.
  2. Disconnect all accessory devices from your computer (digital camera, camera dock, printer dock, photo printer, card reader, etc.).
  3. Verify that you logged on to the computer using the administrator account.
  4. Close all programs.
  5. Download the software.
  6. When the download is complete, select Start > Programs > Kodak > Kodak EasyShare > Kodak Easyshare software.
Mar 06, 2011 | Kodak EasyShare C613 Digital Camera
I have a Kodak easyshare C613, when i plug the camera into the usb to get the pictures on the PC, it comes up with the error "the USB has malfunctioned and that the computer doesn't detect it" It has...
If this problem still is not fixed you can go online and purchace the DeOxit and add a drop onto your USB port and USB plug in hole - you may not be making good connections...($6 easy repair)
Oct 08, 2010 | Kodak EasyShare C613 Digital Camera
None of the software on my computer recognize the videos on my Kodak EasyShare C613, what software do I need or how do I do this?
The Kodak EasyShare C613 digital camera uses the QuickTime motion JPEG format for storing its videos. Apple QuickTime is a free download from Apple's website.
I hope that helps.
Mar 20, 2010 | Kodak EasyShare C613 Digital Camera
I need the drivers for a kodak c613 zoom digital camera
you can download the drivers and its software at kodak.com/go/easysharesw., just click download for free., the latest software version will work with the camera just make sure that the minimum requirements is pentium 4 2.0GHZ
Oct 31, 2009 | Kodak EasyShare C613 Digital Camera
Can't connect my Kodak C613 digital camera to my computer.
For solving your problem it is necessary to remove your Easyshare Software completely from your system. Afterwards you need to install the latest version of Easyshare Software. Please follow the steps below: Remove Easyshare Software Click on 'Start' -> 'Settings' -> 'Control Panel' -> 'Software' Please choose 'Kodak Easyshare Software' Please choose 'remove' Please click on 'next' when installation wizard shows up Please choose 'remove' and click on 'next' Please click on 'next' to start the removal of your Easyshare Software. Please make sure that all files of your Easyshare Software has been removed from your system successfully. For remaining the progress please go to step 2. Even if you couldn’t remove the software or it is still in the list. For running Kodak Clear Utility: Please go to www.kodak.com/go/clear and follow instructions given on screen. Click on 'download'-button below on screen. Please choose 'open' and follow instructions given on screen. Please choose option 'save as' after choosing the download option to run clear utility from your PC. Please choose a save path. Open file clear5N.exe after file has been saved. Click on green starting arrow. The programme is running now. Please note! Please click on 'Ok' should messages appear for which you only have 'Ok' as an option that will make sure that you still run the programme. Should you been asked to restart your computer, please choose 'NO'. You receive the following message when the programme has finished: 'Easyshare files have been removed. Please reinstall Easyshare after system reboots'. Your computer will be restarted now. This action removes Easyshare Software from your system but it won’t delete any pictures or videos. But there is the possibility that you have to recreate your collection after reinstalling the Software. We recommend to download always the latest version of Kodak Easyshare Software. You have either the option to download the software free of charge by following the link: http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn026079.jhtml?pq-path=4509
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 30, 2009 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C613 not able to connect through USB
I had part of this problem. Click on the "add pictures" button, and find your camera on the screen in the upper left hand part. THen choose the photos you want to download. That is how I do mine. If that doesn't work, just keep trying. I had to try for a LONGGGG time to get mine to load. I used to have to pay to get my photos on a disc..
Jun 01, 2009 | Kodak EasyShare C613 Digital Camera
I have Kodak EasyShare C613 camera. I have some nice pictures on the memory card. My WinXP recognizes the camera, but won't find any drivers for it. So camera is detected, software running, but i'm not able to transfer the pictures, because I can't connect to camera. Any ideas to solve this?
Nov 03, 2007 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
727 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
