NDDN W56 "please insert correct map disc"
I am having a problem with my car dvd its shows "please insert correct map disc" kindly send me solution. e-mail: human_point@yahoo.com
  • 2 more comments
  • shapoor lahorzoy Jul 15, 2019
    i am having a problem with my car dvd
    please insert correct map disc kindly send me solution app
    shapoor.lahorzoy@gmail.com
    please send my
    please send my
    please send my
    please send me solution
    New Friend:
Name of the Software: Voice Navigation System JAPAN A26 (NDDN-W56) 08664-00L96 86271-60W250
Persons who are having problems with their navigation system in their Japanese Toyota car. Their DVD Deck remains stock in one screen that shows "Please insert correct map disc."
Solution:
The software was loacted at this website http://www.torrentino.com/torrents/124595.
After downloading the software, burn software LOADING.KWI on a blank DVD. (Note: Let this be the only software on the blank DVD and I use a blank DVD-R).
Place 86271-60W250 has the name of the blank DVD.
Burn DVD at a 4x speed.
Insert into the Map Drive of the DVD deck.
Hope this was helpful.
Posted on Jun 07, 2012
    New Friend:
Http://nddn-w56.blogspot.com/
Posted on Jul 24, 2017
    New Friend:
The disk is currpted try another disk
Posted on May 05, 2017
    New Friend:
  • 34 Answers
ELECTRORAMA HAVE THE BOOT CD TO FIX IT ...TRINIDAD PH.#662-6387..THEY ALSO CONVERT FM TO RECEIVE LOCAL RADIO STATIONS... DAVID & DANIEL..
Posted on May 12, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: LG DVP7772 Portable DVD Player with Screen showing disc error
its aged and old, all pordable dvd players stuff up eventually, get a new one.
Posted on Aug 10, 2008
mysus
SOURCE: Problem in Copying Recorded Material from Hard Disk to a Blank DVD
Please refer to the https://www.fixya.com/support/t562814-hr_720_not_burn_dvr_r_media - it seems I have found a solution, maybe it can help also here
Posted on Aug 17, 2008
Anonymous
SOURCE: Error C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
Posted on Oct 30, 2009
sexyvalente
  • 5 Answers
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
Posted on Feb 16, 2010
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: when i insert a disc in my dvd player it reads "no
Hi mgarragh1,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 23, 2011
Car dvd
Hi ALi i am facing problem "please insert correct map disc" in NDDN-W56. would you please send its software at my address.
waqas_hussain51@yahoo.com
thanks
Jun 08, 2013 | Car Audio & Video
Change language to english in dvd NDDN W56
please help me too i ve the same problem triniryan@gmail.com, thanks
Mar 25, 2013 | Car Audio & Video
NDDN-W56 Unlocker software
hi Aliadnans
need a help please, for ''insert correct map disc'' NDDN W56 device.
my email: distingue8@yahoo.fr
Jun 21, 2012 | Car Audio & Video
Nddn w56 problem
Good day Ali Adnan,
I'm in need of your assistance. Would you be able to send me the software that can resolve "Please insert correct map disc" issue for model NDDN-W56 (76031).
my email address is lackraj.smith@yahoo.com.
Much Thanks!!!!
May 15, 2012 | Car Audio & Video
NDDN-W56 car DVD player shows "PLease insert
check there...
http://www.gps-guru.com
Apr 27, 2011 | Car Audio & Video
No installation softwere for gps dvd player NDDN W56 in english
Software for NDDN-W56 is only available in Japanese if its in Japanese by default.
if you want solution for ERROR" Please insert Correct Map CD" then post your email address here I will send you NDDN-W56 software Torrent for downloading along with instructions. 100% working on NDDN-W56
Mar 24, 2010 | Panasonic Car Audio & Video
Televison & Video Logo
11,119 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
