fail on self test check if all parts(developer,drum toner are correct installedfail on self test check if all parts(developer,drum toner are correct installed
You can't post conmments that contain an email address.
If your Ricoh MP5000 printer is displaying the "Please Wait" message, it may be due to a problem with the printer or an issue with the print job. Here are a few things you can try to fix the issue:
Restart the printer: Sometimes a simple restart of the printer can fix minor issues. Turn the printer off, wait a few minutes, and then turn it back on again.
Check for errors: Check the printer's control panel for any error messages or codes. These messages can help diagnose the problem.
Cancel the print job: If the "Please Wait" message is displayed while a print job is in progress, try canceling the print job. You can do this through the printer's control panel or by using the printer's cancel function on your computer.
Check for paper jams: If the "Please Wait" message is displayed while the printer is attempting to print, there may be a paper jam. Check the printer for any jammed paper and remove it if necessary.
If these steps do not fix the issue, there may be a more serious problem with the printer. In this case, it is recommended to contact Ricoh customer support or a printer repair technician for further assistance.
solution : 1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer. 2. Reinstall driver printer (don't connect printer USB cable to computer). Wait forthe install process,untilmessage "connecta printer USB cabletocomputer". After message appear, connect printer USB cable to computer. 3. Wait process install finish and try to print.
Please try this solution.
Remove the USB cable into the printer and leave the printer on. Remove all the cartridges. Close the cartridge door and wait for the INSERT INK MESSAGE to appear. Disconnect the power cable and from the power source supply. Now open again the printer door. Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes Reconnect power cord and turn on the printer. Return all the ink cartridges and close the door. Wait for the calibration process. Print the test page to check if it working. Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Remove the USB cable into the printer and leave the printer on. Remove all the cartridges. Close the cartridge door and wait for the INSERT INK MESSAGE to appear. Disconnect the power cable and from the power source supply. Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes Reconnect power cord and turn on the printer. Return all the ink cartridges and close the door. Wait for the calibration process. Print the test page to check if it working. Reconnect the USB cable and try to print again.
Hi there
Try the following steps to remove HP Printer Error Code 0xc18a0001. I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable. 2. Remove the cartridges. 3. Wait until the message "Insert cartridge" appears. 4. Unplug the power cord. 5. Wait 60 seconds. 6. Reconnect the power cable. If the printer does not turn on automatically, press "On button". 7. Reinsert the cartridges and close the lid. 8. If the printer has a page of calibration accept. 9. Reconnect the USB cable and remake an impression. 10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message. * Simultaneously press the keys "9" and "#" printer. * While holding the button down, unplug the power cord from the unit. * Wait a few seconds. * Still holding the button down, reconnect the cable and turn on the printer. * Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message. * Simultaneously press the keys "9" and "#" printer. * While holding the button down, unplug the power cord from the unit. * Wait a few seconds. * Still holding the button down, reconnect the cable and turn on the printer. * Release the buttons.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
I had exactly the same problem. Called Konica Minolta, and the best they could offer was 'Power down and then back up again". I did this but still had the same "please wait" that didn't go away. Then I powered down, unplugged the power cord, left a few minutes, then plugged in and powered up again. This time the printer went through a lengthy and noisy startup process, even printing out a status page. I then tried again, and this time immediately afte the "please wait" I got the "open door" as expected, and was able to replace the toner successfully.
I suspect though that you are right, and that the correct cartridge does get positioned automatically, and the "open door" message is not necessary. It would be nice if someone could confirm though.
try to reinstall your printer and if the error message show up again try to check your printer to the HP customer care mybe the problem from your board printer
Hi there 0xc18a0001.
Or try 2
Or try 3
Or try 2
Or try 3
